Frigidaire PLEF398AC Electric Kitchen Range Logo
A
Anonymous Posted on Nov 21, 2017
Stop the factory default beeping
How do I remove the piezzo beeping from my new range. The owners manual describes the procedure but it only turns off some of the beeps. I need to now how to access the piezzo buzzer and dismantle it. I believe the plastic cover snaps or unscrews off to expose the small tin sound board that I can remove and replace the cover.
Don Eagan
Level 3:
Master:
  • Master 714 Answers
  • Posted on Nov 21, 2017
 Don Eagan
Master
Level 3:
Master:
Answers
714
Questions
5
Helped
271980
Points
4898
What is the name and model number of your range?
5 Related Answers
Anonymous
  • 114 Answers
  • Posted on Apr 27, 2007
SOURCE: FRIGIDAIRE GAS RANGE LGLGF388DS
I WOULD TRY UNPLUGGING YOUR APPLIANCE. TURN GAS COCK "OFF" (BY LAW THERE SHOULD BE ONE NO FARTHER THAN 6 FEET FROM YOUR STOVE) PLUG STOVE BACK IN. SEE IF IT MAKES THE SAME NOISES. IF IT DOES, CALL THE GAS COMPANY TO SEE IF YOU HAVE THE PROPER GAS PRESSURE GOING TO THE APPLIANCE. (SOME GAS COMPANY'S STILL WILL CHECK THIS AT NO CHARGE". NEVER TRY TO REPAIR ANY GAS OR ELECTRICAL APPLIANCES YOURSELF. FIND A LISCENSED APPIANCE REPAIR COMPANY IN YOUR AREA (SEE IF THEY ARE LISTED IN THE BBB AND HOW LONG IN BUISNESS) UN FORTUNATELY, ALL THE NEW APPLIANCES WITH ALL THE NEW "BELLS AND WHISTLES" ARE USELESS AND COSTLY TO REPAIR IN MOST CASES. DONT GET RIPPED OFF MAKE SURE THE REPAIR COMPANY IS CERTIFIED TO WORK ON YOUR MAKE AMD MODEL. Joe_Rex (New Member)
Anonymous
  • 89 Answers
  • Posted on Dec 16, 2007
SOURCE: IT WON'T STOP BEEPING!
I hate to say it, but the touchpad or computer board needs to be replaced. VERY expensive...goodluck
Anonymous
  • 481 Answers
  • Posted on Jul 12, 2008
SOURCE: burners will not turn on and it beeps code f5
the fault codes can be found here: http://www.repairclinic.com/0078.asp#Frigidaire
  • the codes depend on what version of stove you have, that is why i used a link to them.
  • double check your wiring and make sure nothing is shorted out or wired incorrectly.
  • all the burners share the same neutral wire so that is where i would look first.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
    Mike
Anonymous
  • 750 Answers
  • Posted on Oct 17, 2008
SOURCE: I need help with my frigidaire self cleaning confection range it is flashing F1
Hello traden,
Welcome,
You said, What do I do to get my range to stop beeping and flashing F1
Please send me your complete model number including that number at the end of the model number.
pull open the storage drawer and you will find a sticker down low on one side.
Mean while you may try unplugging the range for 5 minutes and that should reset the system if it is only a glitch!
Waiting for your Complete Model number.
Huuum
cjfmc
  • 39 Answers
  • Posted on May 22, 2009
SOURCE: Starts beeping and F31 ERR flashes
Its a shorted probe connection.
check resistance at room temp if less than 500ohms replace rtd sensor probe.check for shorted sensor probe harnessbtween EOC and probe connector
GE JGBP83WEJWW Gas Kitchen Range
Amy, F1 indicates that your ERC (electronic relay control) OR your keypad has failed. Here is the test procedure to determine which... GO OUTSIDE AND SHUT THE BREAKER OFF!!! Open the top oven door (the model number you posted is incorrect, I don't know if it's a single or double oven but the procedure is the same)and look at the bottom of the keypad console. You'll see 3 screws under there. Use a 1/4" nut driver or socket to remove these. Then remove the control panel (lift and rotate toward you). From here, you'll see the back side of the ERC. Look for the green "ribbon" coming from the keypad and inserted into the ERC. Remove the ribbon cable from the ERC and let it dangle all by itself. Then replace the control panel in the reverse order from what I described above. Now turn the breaker back on. OK.... this is waiting period. Now that the keypad is disconnected you've isolated the 2 components. If the F1 error reoccurs, the ERC is the problem. If not, it's the keypad. The time frame for this diagnosis is 24 hours. If, after that time, the error does not show it's definitely the keypad.
How can i stop my dvr to stop beeping and switching off
You probably need a factory reset (button, or procedure) to default values, some collision occurs here. Otherwise ask authorized service. DAP
privatni detektiv agencija za detektivske usluge privatnog detektiva...
It wont stop beeping
CHECK IN THE OWNER'S MANUAL IF THERE IS A RESET PROCEDURE.
2helpful
Locate reset button on insignia ns-ltdvd 19-09, and the reset procedure to follow.
There is not an external reset button on this TV. To reset to factory defaults, enter the onscreen menu system and highlight the OPTION icon using the arrow keys. On the resulting screen, select "Restore Default." I would also recommend power-cycling (turn the TV off and unplug for several minutes) as part of your reset procedure. Additional details can be found in the owner's manual.
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
Need manual
f you have forgotten the password, you can reset the WiFlyer to use factory defaults for all settings using the following procedure. leading.gif leading.gif leading.gif 1. Disconnect the power cable from the back of the unit. leading.gif leading.gif 2. Press and hold down the "quick connect" button. leading.gif leading.gif 3. Re-apply power while continuing to hold down the button. leading.gif leading.gif 4. Release the reset button once all 5 lights have come on and the unit has beeped 3 times. leading.gif leading.gif 5. If unit does not beep (volume off), wait for the lights to start coming on a second time before releasing the quick connect button (about 12 seconds). leading.gif leading.gif Note:
Resetting to factory defaults will remove any custom configuration, including access numbers, that you have entered and you will need to configure the base station again.
No sound
Try Referring to Owners manual about the Intialization procedure. This will reset unit to factory defaults. Then try setting up like you bought it new. Procedure enatails pressing two buttons when turning on main power switch. . All leds will light up to let you know Unit has been initialized. Denon provides free manual downloads if you don't have manual.
Oven control panel
Lok at your manual tp view all the possible control options. However, the solution could be; The touchpads, in conjunction with the dial, are used to select an oven mode,
set the oven temperature, set the time(s) and to set up your range. To use the
touchpad, press the center part of the pad with the flat part of your fingertip. A
beep will sound to indicate that the selection has been made. Turn the dial to the
desired setting and press START.
Pull the plug or flip the circuit breaker, wait five seconds and plug in the range or flip the circuit breaker to on. Always set the clock after installation or after a power failure. Once power returns to the oven, the clock defaults to 12:00 am.
Clock time display can be turned off. The default display is on.
1. Access SELECT FUNCTIONS Menu.
2. Turn knob clockwise until CLOCK DISPLAY is displayed.
3. Press START.
4. Turn knob to select ON or OFF
5. Press START to accept new selection.
Reset the Factory Settings This feature is used to change all the “Select Functions” settings back to the original factory settings (or defaults).
2. Turn knob clockwise until RESET DEFAULTS is displayed.
3. Press START. Display reads SELECT FUNCTIONS.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
