AKASO KingPad 7 Google Android 4.1 Dual Core IPS Tablet MID PC, Rockchips RK3066 Dual Core Cortex A9 CPU up to 1.6GHz, 1Gb RAM, 8Gb HDD, HD IPS LED Multi-Touch Screen 1024x600, Front Camera Rear Camera, Google Play Pre-Installed, HDMI 1080P Output, Skype V Logo
A
Anonymous Posted on Jan 25, 2014
Stuck on home screen - AKASO KingPad 7 Google Android 4.1 Dual Core IPS Tablet MID PC, Rockchips RK3066 Dual Core Cortex A9 CPU up to 1.6GHz, 1Gb RAM, 8Gb HDD, HD IPS LED Multi-Touch Screen 1024x600, Front Camera Rear Camera, Google Play Pre-Installed, HDMI 1080P Output, Skype V
My alcatel one touch is stuck on the screen logo
5 years later... (note while charging!)
hold the power button and the volume down button until the screen turns back on, then keep holding the volumes down button while letting go of the power button, keep holding for a while fr, then it should say the version name, and where u got it for me "T-moblie" bam to my Home Screen!
1helpful
2answers
How do I unfreeze a Google app page?
Reset the App
1. Double-click the Home button. This minimizes the app and displays the iPad's multitasking screen.
2. Drag the stuck app upwards on the screen. This forces the app to close and removes it from the iPad's memory.
3. Press the Home button to display the iPad's home screen. Tap the app's icon to relaunch it. Any unsaved data, like words you typed in a document or progress in a game, is lost, but the app opens and should respond normally.
4answers
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
9helpful
3answers
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Top AKASO Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an AKASO Tablet and eReader Expert? Answer questions, earn points and help others
