Question about Pelican $80 Performance Cobra Tt Racing Wheel Green W/pedals For Xbox Working
Pelican Cobra TT racing wheel
Can't hook it up. Odd cable?
2 Suggested Answers
SOURCE:
SOURCE: need a pc converter adapter for a pelican cobra tt racing wheel
amazon ps2 to a ps3 converter
Posted on Aug 22, 2010
I have a cobra 29 LX Max that I hooked up and everything passed. I later changed the power cord and now it says antenna fail when running test and antenna warning when I key up. I can receive,transmit
That is odd. I would unplug the unit. Now unscrew the antenna and check the connector attached to the coax. If you can unscrew the antenna, use a continuity meter and test the cable with the connector. Sometimes connectors whether installed by you or a factory simply fail, or the solder fails. You may need to replace or resolder the connector. Best of luck and post your results.
Feb 12, 2017 | Cobra Radio Communications
Need manual for pelican system selector pro s-1037
The pelican doesn't upscale. If you have yellow white red connecting something to the pelican, you need yellow white red connecting the pelican to the TV, not just component cables.
Jul 05, 2012 | Pelikan Score System Selector Pro S-1037
I plugged in the Pelican Cobra TT Racing to my PS 2 (Cars Game) and the buttons and pedals work but not the steering motion. Help?
It could be the game not being compatible with the wheel, but it could be the wheel too. Ask the friend you got it from which games he played with it and see if you can borrow that game. Test it with that game to see if it works. If so, the Cars game is not compatible with the wheel. If this is not the case, the wheel is faulty. You can try to clean it by disassembling it and cleaning it from the inside, but many analog controllers can break pretty easily, and if that's the problem, the wheel is pretty much dead. I hope that the Cars game is not compatible.
May 21, 2012 | Pelican Cobra TT Racing (6770936FA)
Need for speed shift doesent reconize
hey i am having the same problem the only thang i can use is the wheel but not the pedal? r u having the same problem?
Mar 05, 2010 | Pelican Cobra TT Racing (6770936FA)
RACE AND HOOK NOT ASSEMBLED CORRECTLY IN MACHINE 534FB
Turn the hand wheel until the hook race ON YOUR MACHINE is in the left position ...insert your hook ( semi circular hook) to the right side( jagged edge to the bottom)...insert the hook race cover ( circular, with the two jagged points facing inwards and in 12 o'clock position) and snap back the two hook retaining arms. Ready for inserting bobbin case. Good Luck
Apr 30, 2009 | Singer 8280 Mechanical Sewing Machine
My sensitivity on my Pelican PL624 Cobra TT is bad how do i change that?
i'm sorry to say but even on max sensitivity this wheel is very unresponsive. i suggest you just save up and buy a higher quality wheel
Feb 28, 2009 | Pelican Cobra TT Racing (6770936FA)
Oil prablem
Remove the bobbin case.Snap the two retraining arms outwards.Remove the hook race cover and the hook. Oil on right hand side about 4 O'clock... 1-2 drops of oil.Turn the hand wheel until the hook race is in the left position...replace the hook...replace the hook race cover and snap back the two hook retaining arms. Good Luck
Feb 02, 2009 | Singer 1120 Mechanical Sewing Machine
Pelican $80 Performance Cobra Tt Racing Wheel Green W/pedals For Xbox Working Logo
Top Pelican Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Pelican Video Game Console and Game Expert? Answer questions, earn points and help others
