My unit is a kerosene 35000 btu unit...just had similar issue.
It is very possible that the spark plug is
- fouled out (dirty)
- mis-gapped
take the top cover off, you will see the plug. There is a sheetmetal plate held on by two screws holding the ground, plug, and nozzle together. It is easier to just remove the plate (you will have problems with the plug nut if you don't).
remove the plug with a plug socket, probably 5/8.
I used brake parts cleaner to spray off the electrode of the plug then a wire brush to clean it.
check your plug gap...this might be crucial. my gap was specified on a label stuck on the inside of the bottom of the body. The plug on my unit was way too small. Adjust gap if necessary using feeler guages.
reinstall parts and plate. (I actually tack-welded the plug nut into place for ease of maintenance later). Note that the electrode needs to be a specific angle, relative to nozzle....probably diagrammed on the same label as the gap spec.
replace top and see if she'll fire up.
...last note...also might check your fuel pickup/filter. It is located behind the side panel in the unit
good luck...hope I have helped you
