Samsung LN52C530 52" LCD TV Logo
A
Anonymous Posted on Jan 24, 2014
Backlight part number for backlight
2answers
What is the backlight part number for samsung tv UN55FH6200. Is it BN44-00499A?
If you wish to get some details about LCD LED television ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Backlight repair for p845t-s4305
You will want to take this into a local PC repair shop to have them repair this; Not all PC repair shops do this type of work.
If you want to do this yourself, look up the backlight part number based on your model of laptop, and order the backlight.
We can't see LED light chip directly
Post the laptop manufacturer name, and model number.
The model number is on the Bottom of the laptop.
Post in a Comment.
Plus add additional info about what are you referring to?
Offhand, I would guess a reference to the LED backlighting on the laptop.
If this holds true, and you have no Backlight, the normal procedure is to replace the LCD screen.
With most laptops utilizing LED's as a Backlight, the LED backlighting is incorporated into the LCD screen assembly, and that's why when the LED backlighting goes bad, the LCD screen itself is replaced.
Post back in a Comment.
Regards,
joecoolvette
No back light
Hello
If sound output is OK, and there is no picture, the fault is with backlight section itself. Check its backlight CCFL lamps, and backlight inverter board for fault. This is the picture of the backlight inverter board to your TV. It can ble located at the left side of the display panel. There is norepair to this bard other than repalce it with same type and number. Before replace it, check whether proper voltage comes to it from the main power regulator board.2_16_2012_4_51_14_am.jpg
Black screen with sound no picture
Hello
You haven't either given its Brand name or its Model number. Anyway, as it is an LCD TV, this is common fault to all brands. Check its backlight CCFL tubes, and the backlight inverter board.
Actually there is picture, but you cant see it as there is no backlight. OK.
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
1helpful
Is there a backlight replacement kit for the Hanns-G Hw191D if so do you know the cost and where to get it?
You can look on ebay and find your backlights cheep. you can Bing that model number along with Backlights and get a idea of who, where and how much.
Part number for the samsung le52m87bd backlight inverter
Hey!
I also have a SAMSUNG LE52M87 LCD TV and I have the same
ANOYING BUZZ comming from ( I think ) backlight converter. - I am
almost 100% that its because of the backlight inverter while the sound shifts frequency when backlight is changed ( from 1 - 10 ), but the volume of the buzz stays the same. Only the tone changes. I have this TV for a year now and havent realy noticed until now, so I think it started buzzing recently, because I didnt hear it before ( and I got realy sensitive hearing :) ) ...
ITS DRIVING ME CRAZY ...
PLEASE post what happened when ( if ) you changed the inverter,
or what did you do to solve the problem ...
Many thanks in advance!
Eddie from Slovenia
my email: [email protected]
1helpful
Backlight
try changing the LCD screen
Keypad backlight function turns off when call is connected
Plain and simple there is something wrong with the LCD on your phone, needs to be repaired if possible
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
