In my micromax Q7 mobile all incoming calls are replied with this number is busy. Neither I locked nor barred the calls, knowingly or unknowingly. Please get a solution.
The @ represents pressing the "Send" key on your mobile
##002#@ all call diverts off *#06# IMEI Number showing **004*DestNo#@ set all conditioned call diverts to DestNo on and active ##004#@ all conditioned call diverts (busy, not reachable, no answer) off **21*DestNo#@ Automatic divert all calls to DestNo on and active *21#@ Automatic divert all call DestNo activate ##21#@ Automatic divert all calls to DestNo off and inactive #21#@ Automatic divert all calls to DestNo deactivate *#21#@ Automatic divert all calls to DestNo status **61*DestNo#@ Call divert when not answered on and active *61#@ Call divert activate ##61#@ Call divert when not answered off and inactive #61#@Call divert deactivate *#61#@ Call divert when not answered status **62*DestNo#@ Call divert if not reachable on and active *62#@ Call divert activate ##62#@ Call divert if not reachable off and inactive #62#@ Call divert deactivate *#62#@ Call divert if not reachable status **67*DestNo#@Call divert when busy on and activate *67#@ Call divert activate ##67#@ Call divert when busy off and inactive #67# Call divert deactivate *#67#@ Call divert when busy status **03*330*oldPW*newPW*newPW#@ Changing the password for call barring **33*PW#@ Barring all outgoing calls on (PW one row before) #33*PW#@ Barring all outgoing calls off *#33#@ Barring all outgoing calls status **330*PW#@Barring all calls on #330*PW#@ Barring all calls off *#330*PW#@ Barring all calls status **331*PW#@ Barring all outgoing international calls on #331*PW#@Barring all outgoing international calls off *#331#@ Barring all outgoing international calls status **332*PW#@ Barring all outgoing international calls except homecountry on #332*PW#@ Barring all outgoing international calls except homecountry off *#332#@ Barring all outgoing international calls except homecountry status **333*PW#@ Barring all outgoing calls on (PW one row before) #333*PW#@ Barring all outgoing calls off *#333#@ Barring all outgoing calls status **35*PW#@ Barring all incoming calls on #35*PW#@ Barring all incoming calls off *#35#@ Barring all incoming calls status **351*PW#@ Barring all incoming calls if abroad on #351*PW#@ Barring all incoming calls if abroad off *#351#@ Barring all incoming calls if abroad status **353*PW#@ Barring all incoming calls on #353*PW#@ Barring all incoming calls off *#353#@ Barring all incoming calls status *43*#@ Call waiting on #43##@ Call waiting off *#43#@ Call waiting status **61*DestNo**Seconds before divert#@ Divert call if not answered for 'seconds' (Note: Seconds must be 5, 10, 15, 20, 25, 30) #30#DestNo@ No presentation of the number of the incoming call (CLIP) *30#DestNo@ Presentation of the number of the incoming call (CLIP) *#30#@ CLIP status #31#DestNo@ Your number will not be send for the actual call (CLIR) *31#DestNo@ Your number will be send for the actual call (CLIR) *#31#@ CLIR status *76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) on #76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) off *#76#@ Presentation of the number under which I reached the other one (not his number if he has turned on a call diversion!) (COLP) status *77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) on #77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) off *#77#@ Presentation of the number under which the caller has reached me (not my number if I have turned on a call diversion!) (COLR) status
Hi, since it is a nokia phone, and on the phone it has service signal bar showing on the screen of the phone, Just apply this codes #33#0000#( to cancel any beared calls(both in and out going calls and #002# ( to cancel any call divert on the phone.
NOTE: it will only work if the service signal bar on the phone the makes you know that there is service on your is full. If not, that means the phone network will be the problem which you will need to consult repairer.
Please make sure your outgoing and incoming calls are not barred.
go to settings go to call settings go to call barring and check the status of your outgoing and incoming calls.
There is also a line 1 and line 2 facility. Make sure you are using Line 1
This is probably due to a damaged mainboard. It happened in my sony K770i and im afraid its a write off. I had the same problem it was as if the imei had been blacklisted.
I flashed and flexed the set but to no avail, tried a software update but no update was available from motorola. I then went to the Security settings of the set and restricted all outgoing calls and restricted all incoming calls except the phonebook entries. Then I dialed my mobile using a landline which was on my phonebook and my phone started recieving the calls, then after that I allowed all incoming and outgoing calls. This solved the problem. I believe it is sheer luck because I tried that step earlier on the same day but it gave no result.
Hey dude, One thing, if ur nokia N95 is china mobile. U cannot access or have connection to internet. If it is NOKIA branded, consult a mobile technician or ur SIM operator for GPRS settings. ===============================================
Send me a feedback and rate my solution too.
Dont forget to post a clarification request for ur problem after it is solved.
=============================================== SAJAN([email protected]/[email protected])
