My tv will not turn on - the power button is blinking red six times in a row and then stops. I have a Sony KDF-E60A20 for about 2 1/2 years when the TV just shut down. A red indicator light on the front of the TV flashes six times. I replaced the bulb but did not repair the problem. Can someone help me.
A 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Have you checked to see if all the fans are running?
