Klean-Strip Adhesive Remover Voc Logo
A
Anonymous Posted on Jan 23, 2014
Is klean strip adhesive remover okay to put on dry wall?
Tim Hunt
Level 2:
New Friend:
  • Expert 68 Answers
  • Posted on Oct 02, 2017
Tim Hunt
Expert
Level 2:
New Friend:
Answers
68
Questions
0
Helped
44635
Points
189
Yes-just let dry after-then on prep of wall after you may have to skim wall with a thin coat of drywall compound and sand smooth
I am prepping a back splash wall for tile I applied one coat of joint compound and before it dried it cracked is the product defective or am I do it wrong.
Joint compound shrinks when it dries If it cracked, you put it on to thickly. When you cover it with adhesive to mount the back splash, it shouldn't matter. If you want it to be smooth first, you can put a THIN coat of joint compound over it first. However, the cracks that are there will probably help the adhesive hold to the wall.
Jan 28, 2019 • Home
Can this clean rust from steel?
Yes it will, there other, better ways though.
How can I fix tile backer to honeycombed drywall
Get you some heavy duty liquid nail or similar adhesive, put it in strings/loops, wait a bit, put rock on, hold a bit done
Mar 15, 2015 • Drywall
How to remove linseed oil
scrape of as much as you can with a plastic scraper to min any damage. The use paint thineer to clean off the rest.
Edging a worktop
The best thing to use is contact cement or super 77 spray adhesive. Put either one on both surfaces, let dry, set it back on and use painters tape to hold on for 24 hrs.
Jan 24, 2014 • Hand Tools
1helpful
2answers
How to hang a mirror without nails
Instructions
    • 1
      Select a location to hang your mirror by holding it up on different areas of the wall. If possible, ask another person to hold the mirror while you stand on the other side of the room to judge the best spot for displaying it. Once you've decided on a spot, mark the wall lightly with a pencil along the top and bottom edges and/or corners of the mirror.
    • 2
      Place a level against the wall horizontally at the top pencil marks and tilt it up and down slightly until the bubble centers inside the glass tube in the level.
    • 3
      Draw a line lightly with your pencil along the edge of the level.
    • 4
      Lay a thick towel or blanket on a flat work surface and place the mirror on top of it, reflective side down.
    • 5
      Wipe the back of the mirror with a damp cloth to remove any dirt or debris sticking to the surface and wait 15 to 20 minutes for it to dry. In addition, wipe the wall down and wipe or air-dry it. If either surface has greasy or oily stains or other marks, wash the surfaces with mild detergent, rinse thoroughly with a damp cloth to remove any residue, then wipe or air-dry.
    • 6
      Affix strips of heavy-duty, double-sided, mirror-mounting tape to the back of the mirror along the sides, top and bottom.
    • 7
      Remove the paper backing from the double-sided tape strips, align the top of your mirror with the pencil line on the wall and press the mirror firmly against the wall.
    • 8
      Erase any visible pencil marks.
Tips & Warnings
  • If you need to mount a heavy mirror without putting a hole in a wall, hire a professional mirror installer.
  • Never touch the adhesive surface with your fingers because you can transfer oil to the adhesive that can reduce its ability to bond to surfaces.
Related SearchesReferences
I own an acer 10.1"
it isnt that difficult actually , a how to for removing the lcd is shown here
Remove the four screw caps and screws from the LCD Bezel.
NOTE: The two center screw caps at the top of the bezel are for protection only.
Starting from the inside top edge, pry the bezel away from the panel. Continue moving down the sides until the bezel is removed. If necessary, use a plastic pry to release the corners of the bezel.
1063_66_97.jpg 4. Lift up the bezel and remove it from the LCD Module.
IMPORTANT: If the LCD Bezel is replaced, remove the lid sensor magnet from the bezel, and attach it to the replacement bezel.
  1. Disconnect the cable from the Camera Board as shown.
1063_66_99.jpg Remove the Camera Board from the LCD Module.
  1. Remove the four securing screws (two each side) from the LCD Panel brackets.
1063_66_104.jpg Turn the LCD panel over on a clean surface. Remove the adhesive strips securing the LCD cable.Carefully lift the adhesive tape securing the cable connector to the LCD Panel.
1063_66_105.jpg 5. Hold the adhesive tape clear of the LCD Panel and disconnect the LCD cable as shown.
  1. Remove the adhesive strips holding the MIC cable in place.
1063_66_107.jpg 3. Remove the MIC Board from the LCD Module.
  1. Remove the adhesive strips holding the Camera cable in place.
  2. Remove the Camera cable from the LCD Module.
  1. Remove the adhesive strips holding the Antenna cables in place.
1063_66_110.jpgCarefully pry up the Antenna pads, as shown, and remove the pads from the LCD Module. IMPORTANT: A strong adhesive is used to secure the Antenna pads in place. Take care not to bend the pads during removal.
to fit a new one do the steps in reverse
If you found this info useful Please vote for me
97 tiburon sunroof seal is unglue- do i need to replace or can i do it myself..
Auto parts store, Weather strip adhesive. Make sure clean surface very well. Wipe down with enamel paint thinner (small amount), let dry. Apply adhesive sparingly, very messy if you use to much. Put seal in place and if you can, close your sunroof to hold in place while drying. Let set for a couple of hours and that should do it. P.S. the glue comes in yellow or black.
2answers
Dash board mount
you can buy a heavy duty double adhesive tape, or use a permanent adhesive, or mighty bond onto your dash board since the gps is still removable
Top Klean-Strip Drywall Experts
ADMIN Eric
ADMIN Eric
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a Klean-Strip Drywall Expert? Answer questions, earn points and help others
