This tv normally runs 24/7. I turned it off yesterday and when I tried to turn it back on today nothing happened. Cou;ld it be a fuse ?
SOURCE: I have a LG dishwasher Model LD-14AT3 It suddenly
Hi First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then it means that the control board has gone bad and
should be replaced. Hope this helps...please post back for further assistance. Daniel
SOURCE: my lg intellowasher won't start
Here's a fix that worked for me today! I couldn't make it turn on for over 24 hours. As a last-ditch effort I put my hairdryer on hot and aimed it at the on/off button. I waited 20 seconds and it turned on! (took about 20 presses of the button). In my mind the heat from the hairdryer is expanding the circuit board so that the things that aren't connecting can connect. Hope this helps!
