I have had my dvr for about 3 years and it still says it is recording but have lost all data and it is not recording
SOURCE: Samsung DVD SH853M Freeview/HDD/DVR. Recorded list - cannot access
The Manual fro this machine is typically vague on the minutae of setting up and performing various functions.
Apparantly the 'standby button' on the handset should be in the 'off' position not the 'on'.
The logic of the layman can seee it as the opposite. This does work..... and thank you for your patience.
SOURCE: Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
SOURCE: Starts recording then stops
The manual says that it can be replaced with almost any standard IDE drive but mine has a Seagate 160GB drive in it so may want to stick with original equipment. Other than tha, any drive SHOULD work.
