Re: The machine quits after a couple of minutes and...
Take the kick panel off there are 3 torques 15 screw or 7 millimeter. remove them and on the left side you will find the tech sheet find out what f13 means and let me know.
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
The error F/13 is
shown on the display due to Dispenser Circuit Error detected
in the washing machine. In this problem check the
dispenser motor.Either
is blocked or its not running in proper direction. This will Help.Good
Luck.
see the details and fix it. God bless you If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
•check the drain filter pumpfor foreign objects
• If the above does not correct the problem replace the pump
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed Your tech sheet? GHW9150PW0Tech Sheet # 8182277Rev #
F/02
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Check the drain hose and make sure it is not plugged or kinked.
Check the drain pump filter for foreign objects.
If the above does not correct the problem, replace the pump
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Error F02 code means Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed. Solutions: Press PAUSE/CANCEL twice to clear the display.
If the above does not correct the problem, replace the pump.
Potential Causes
F/02
Long
Drain
If
NOTE:
Press
Check
the
Check
pump is running.
Check
If
