Yes, if you are a bit handy man and you have the following tools,
1.Set of rachet set
2.A couple of scrow drivers and pliers
3. A blow torch to heat the core of the fan blade.
4. A pully remover.
Herr is a question
Why do you need to change the main blower?
is it noisy and you need to change the bearing?
is the motor burnet out? this case is one out of 100 case.
let me know.
Thanks [email protected]
The 1450 Lincon and the 1450 digital basically does the same things only that the digital is more advance in that it is has mother board whith digital control. it is more acurate in its sttings eg acurate time and acurate temparature setting. It also can give diagnostic massages within the control.
As for your lincoln 1000 series please try and give me the detailed problems, im sure i can help cause i have over 8yrs experinces with lincoln pizza ovens
Yes. UNPLUG THE UNIT!!!! Inside the control box there is a motor control board.On the motor control board there are two sets of terminals to look for. Set one is labeled T1-T2. Make sure you have lots of light and a magnifying glass in case it is hard to read. Carefully pull the two wires and switch them. Set two are labled A+ and A-. switch these as well. You must switch both sets at the same time or the conveyor will run at full speed with no control. The wires might be hard to pull off so carefully wiggle them as you pull.
If it's 3 phase, just reverse 2 of the 3 motor feed wires. It doesn't matter which 2. If it's single phase, the wiring directions should be inside the motor where the wires go in.
have you checked the speed control?? it maybe off on the speed run some empty pans thru and time each one I will need a model to give you the entry and exit times for your model before we can futher. do it 3-5 times let me know
