After loading the washer, it will run ok for about 1 minute, then start beeping & flashing the lights, it flashes 8 times then 1 time
Long fill error code if you have flood safe water hoses replace with regular hoses, this may sound stupid but I have seen this in the field make sure water is turned on, other possible reasons bad inlet valve or no power to valve from control, front load washers are notorious for rubbing a hole in the tube that goes to the pressure switch this switch is what tells the control to output power to the inlet valve also make sure the drain hose hasn't fallen to the floor. Quickest way to eliminate some things start with an empty washer after door locks unlocks and locks again the basket will rotate a few times then water should enter the machine fill to a level in the the basket that is barely above the bottom holes in the bottom then stop this eliminates control and inlet valve , if unit continues to fill and you get water half way up the door glass probably a hole in pressure switch tube I very seldom see a pressure switch go bad hopes this helps.
SOURCE: whirlpool awm 9000 auto front loader washing
FH means there is No Water or that's what it thinks.
You either have a water problem or a faulty water valve.
Hope this helps
SOURCE: Our Cabio top load has started to beep multiple times
U probably have a problem with the wirings.
SOURCE: Getting HF error, on Whirlpool Front load washer
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
SOURCE: wrilpool washer front load pump runs all the time
Hello, Thank You for using FixYa. I will be helping you today.Remove the bottom panel there are 3 screws under it.You will see a round white cover it is the drain pump clean-out. Remove the cover and clean it out.Be careful water is going to come out! After cleaning it see if the error stops.
Thank You and please rate my answer if it was helpful..
