After a few minutes the tv starts to flicker and then the picture goes and leaves a white horizontal white with sound.
Can you help
It is a 32' Toshiba TV, about 10 yrs old
Turn the TV off and unplug it from the wall and also unplug everything that is connected to your TV for about 1 minute and plug everything back in again. There could some thing wrong with the power supply or a problem with the t conn board here.
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up.
Stargazer
Also you might try using circuit cooler spray and make the problem show up.
