MONITOR HAS NO DISPLAY AND THE PC BEEPS WHEN TURNED ON
Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem.
depending on the type of beep your motherboard makes you can get to know what your problem is. below are beep code links for various BIOS manufacturers. check yours.
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
http://pcsupport.about.com/od/fixtheproblem/tp/award-beep-codes.htm
http://pcsupport.about.com/od/fixtheproblem/tp/phoenix-beep-codes.htm
Most likely you have a faulty ram, try to use a friends ram to see if that works. make sure that your friends ram is compatible with your computer.
