WSM 1996-1997 Polaris Sl 900 Cc Jet Ski Motor Mount Logo
r
ryan britton Posted on Jan 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It dont like to start up but when it dose it runs good
It dont miss fire or anything when you have it running.... it just really ruff starting
paul
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • WSM Master 1,190 Answers
  • Posted on Jul 08, 2014
paul
WSM Master
Level 3:
Renaissance:
Answers
1190
Questions
Helped
263813
Points
1883
What compressions do you have ? 100psi min !!
3helpful
2answers
2answers
Runs ruff idling when cold!
Check your choke system first, fix any anomalies then if all OK check your carb systems including your air cleaner.
If those steps doesnot resolve your problem ask me again for other possibilities. Good luck
Miss firing engine and black spark plug
Is it a two stroke machine , do you mix your own fuel.
If so over dosing on the oil component will cause your problem, check for the right mix levels and follow them.
Is the choke going full back to zero ?
Are you running the right type pf plug for that engine, some run hot some dont
Is the engine running smooth or lumpy.
For a four stroke engine
Your engine may either be running very rich or there is wear on the bores causing oil to get to the electrode.
You can obtain a spark plug extender which takes the plug out of the direct line of fire
2answers
Our 1995 nissan maxima started running really ruff when starting
dont go changing bits ,then find it still doesnt work ??chances are they are right but take it to garage as an incorrect diagnosis will cost you money in the long run
1helpful
2answers
1991 deville idling very ruff
Hi you should change the coolant temp sensor this is a white sensor on top of the intake and is part ot the computer system.
I have a 1991 F-250 XLT 4x4 4.9L .when i start it up for the first time each day runs good .but try starting it up later that day runs ruff misses an back fires.also when im at 55mph runs good for few mins...
you have a fuel injector leaking
you need to pull your spark plugs and find the cyl that is different and that will be your bad fuel injector and alos replace your plugs
good luck
paul
Top WSM Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a WSM Boating Expert? Answer questions, earn points and help others
