My Afterglow Wireless Headset wont turn off and the microphone light keeps blinking blue. I have tried to wait it out with the battery drain method but when I try to charge it, it just starts blinking blue again. Any help? It started when I was gaming on my XBOX 360 then I heard buzzing then it started flashing blue and it wont stop. The power button does nothing and neither does the mode button. If there is any way to fix this, I will try it. Thanks!
To turn it off press the power button once. To test it you can press the power button, it should blink twice again. Obviously to turn it off again just press the power button.
I think its the mute key. Not sure though haven't used on a console.
Hope this helps
I have the same problem. i am worried. i was playing counter strike and we finished. everybody was congratulating. shortly after a loud beep a bit lower pitch than the turning of and on noise that the headset makes. i turned it on and off. the only thing that stopped the beep was to mute the mic. fiddles with the 2 buttons, the light dimmed greatly and the mic started blinking blue. if you are able to find any way to fix it please contact me on skype : Sassy_Sasquach. Thanks!
SOURCE: Blue light on
i opened it,the upper part does not detach completely but slides,the blue light turned off finally but then on pressing the button nothing happened.Now i'm charging the battery and the blue light is on as usual so i hope it's just out of energy and it will work again when recharge will be finished:)
SOURCE: The headset keeps blinking a red light
I had this very same issue which was remedied when I unplugged the headset recharging dock for approximately 5 seconds then plugged it back in. After about 10 seconds everything re-synced and was fine after that. -No more blinking.
SOURCE: how to sync afterglow ax.4 headset with xbox 360
how do tou fix the after glow ax.4.the problem whith it is that my freinds can hear me but i have to un plug it to hear them
