I have a Sharp Aquos LC-42XD1E and have had it trouble free for about a year or so I would guess. Recently I noticed that there are some horizontal lines in the top left, spaced about an inch or so apart that last for about 4-5". Its just a shadow.... not ghosting of an image, just the same shadowy lines every time its used and always in the same place. Its most pronounced on a soft light colour like light blue or grey. When its a white screen its almost gone and when black its gone. At its worst (only seen this once or twice) then you can notice that the lines are actually part of a 'mesh' like pattern of say 1" cubes across the screen, so I am assuming its part of the telly's construction or something. Please tell me there is a fix for this? Proving to be realy frustrating as you find that instead of watching the program, your eyes keep focusing on the lines and back again...!! This is made even worse as my wife cant seem to see them!!
SOURCE: Screen Goes Blank for about 5 seconds
Try and exchange this for the newer model since I think here was a recall.
SOURCE: Sharp Aquos Won't Power On
I have the same problem with my My LC-42D62U WHen i watch certain DVDs, (so far it happened on SAW III and RUNNING SCARED) during certain parts of those movies my TV will turn off and i cant turn it back on unless i unplug it and plug it back in. It only turns off on specific parts in the movie, i have no idea why...like the same exact parts...so i pretty much have to pause the movie with my remote once my TV turns off then when i power the TV on again just resume the movie and its fine...but if i rewind to that part again it'll power off again SAW III only had one part like that....but RUNNING SCARED had about 3-4
SOURCE: Sharp Aquos LC-32D43U
To adjust screen size, choose the View Mode feature on the top right of the remote control. Zoom size is full screen for watching DVD movies, but sometimes there is still a thin black band due to the formatting of the dvd (unless you buy full screen versions) S. Stretch view mode is best for TV Movies.(usually fills whole screen) Occasionally there are TV movies which just don't respond to being stretched to fill the screen, it's just the way the signal is coming through . 1080i/p detects the resolution of the signal and displays the same number of pixels on the screen, but a 720p signal input will be viewed in full screen.
SOURCE: Sharp 42" flat screen LCD T.V.
You have a bad buffer ic,which is part of the lcd panel.Definiately call sharp to get it repaired.If it doesn't have a warranty,persistence through sharp will get you results.
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
