SOURCE: error code 1 on schwinn elliptical 420
Dear Sir:
adjust the speed sensor see the diagram attached.
2) the main board can be faulty.
3) Run the software calibration.
sincerely. God bless you
SOURCE: An E1 error code on schwinn 420 elliptical trainer
go to next link and proceed according and fix it. God bless you
http://www.ehow.com/how_8453407_fix-1-message-schwinn-418.htm
SOURCE: my schwinn 460 elliptical resistance cannot be changed
see the following details. God bless you
Be aware that the resistance is often the part that requires repair.
Resistance is managed magnetically, so often if the machine is working,
but the resistance isn't setting correctly or at all, check the bolts
that secure the magnets. If they are loose, the resistance will slip. If
the bolts are fine, check the magnets themselves by using a
refrigerator magnet and see if it is attracted or repelled by the your
fridge magnet. If not, the magnets have de-magnetized and need to be
replaced
SOURCE: The digital read out on my 420 elliptical schwinn
follow this steps and replace batteries too. God bless you
Check power problems if the console on the elliptical
machine does not light up. Make sure that the plug for the machine is
secure in the outlet. If it is plugged in, ensure that the outlet is
receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the
elliptical machine. Because different adapters are able to handle
differing amounts of energy, the wrong adapter will not transfer
electricity like it should. If the adapter is pinched or damaged, this
could also alter its effectiveness.
Make sure the correct adapter is being used if the
resistance settings seem to be too hard or too easy. If the correct
adapter is being used, reset the machine. To reset the machine, either
switch the "On/Off" button or unplug the machine from the wall. Doing
this will allow the device to reset itself to the default resistance.
Turn on or plug the device back into the wall and retry all of the
levels of resistanc
