Question about Nordic Track NordicTrack Commercial 1500 Treadmill
The incline motor keeps running - Nordic Track NordicTrack Commercial 1500 Treadmill
How do I clear the E6 code in a Xterra 3.0 treadmill?
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Apr 05, 2017 | Exercise & Fitness
Error code E6 (XQB70-DB14)
24 Hour Locksmith Local Locksmith Locksmith Cheektowaga Ny 716 710 7399...
Aug 07, 2016 | Heating & Cooling
Incline does not work but incline motor runs for 3 to5 seconds proform415ct
if the motor tries to work but incline does not go up something is jammed on the treadmill or the incline motor is bad
Oct 17, 2014 | Proform 415 CT - Treadmills
Reebok z8 feels like its on an incline even when it's on zero incline
1) readjust the speed sensor, clean it and tight the wires connector well
2) see the block diagram.
3) RUN the software calibration for diagnose, troubleshooting , fix it
4) lube the gear and shift elevation motor.
5) adjust the POT, a little and see if you have a better improve.
6) see the diagram, and proceed
God bless you
Jul 09, 2012 | Reebok Exercise & Fitness
How to bypass the incline motor set up on the Trojan stamina treadmill
Dear Sir:
Adjust the sensor speed and clean see diagram
After that RUN the software calibration for easy diagnose and troubleshooting.
See my personal TIPS for diagnose and Help.
Do not Bypass any motor this machine is very advance electronic computer system. IF you do it, only will complicate the system and damaged.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 05, 2012 | Exercise & Fitness
When starting my treadmill the incline just starts all by itself, all the way up, sounds like it would keep going if it could, then it declines, its stuck in this loop. the belt never starts and I cannot...
This sounds like the treadmill is running an incline calibration. It will run to fully inclined, then to minimum incline.
It should not do this every time you want to operate the machine, but they will do it automatically if the operation of the machine is stopped by the power being interrupted..
Jan 26, 2011 | HEALTHRIDER S600 Treadmill Motor Control...
I have an Insight DK614 Tredmill that will not run. It displays an error message "E6" and the running deck will not lower. The motor is still running albeit at a much lower rate. No movement...
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait for 5-seconds and turn back ON.
Also, note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service. Treadmill Error Codes Troubleshooting
Oct 26, 2017 | Exercise & Fitness
Incline is stuck, motor still runs?
First try to calibrate the incline as described in your owners manual.
Start the machine. Press the incline up button. While pressing the button, remove the safety key.
Release the inline up button and reinsert the safety key. The machine should run the full cycle, up to maximum elevation, then back down.
If the motor moves and then resets, you may have an incline motor sensor defect. You will need to order a new incline motor. The sensor is not available separately..
Dec 15, 2010 | Epic View 550 Treadmill
The incline on my proform treadmill is not working and now I can't get the treadmill to start, it just keeps inclining up and down
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Jul 09, 2010 | Proform 650 Crosstrainer Treadmill
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
119 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
