Plug laptop in, get power light but no boot. Have changed memory, jack, processor and motherboard. Still nothing, any ideas
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
SOURCE: Dell GX280 no display
I solved this on a Dell GX280 by removing the CPU and then reseating it in the socket. Also cleaned cpu and heatsink and applied new thermal compound.
SOURCE: Dell Precision 380 won't boot
I had a similar situation with a work computer; the power supply always tested good. A wiser and more experienced computer guru ordered a new power supply. He gave it to me told me to install it, I did and was laughing the whole time. Well it in fact was the power supply. Reason, power supplies are funny like that, they may test good under ideal conditions which is a minimum load put on the unit (enough to boot your system). They are not tested with the stresses of maintaining all your fans, hard drives, mother board, video card, monitor, CD drives, mouse, and keyboard. Its when those loads are applied is when the unit either surges or it is faulty and cannot maintain. First try finding some way to test that suspected bad circuit. If that's not it I would try replacing the power supply, that MAY NOT be your problem but it is certainly CHEAPER than replacing your processor and/or mother board. You could also have a hard drive problem; most drives have self testing features that are partitioned separate from the rest of drive. You can also try plugging your drive into a good computer and see if it boots.
I'll warn you though issues such as yours can take you down a costly road trying to trouble shoot. The components you are thinking of replacing pretty much will give you a brand new computer.
Hope this helps
SOURCE: dell vostro 200 4 repeated beeps on start up
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
SOURCE: My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
