Question about Konica Minolta Bizhub Press C6000 Copier
Error c6704 Keep receiving error c6704. Anyone know what this is or how to fix it?
  • Konica Minolta Master
  • 6,850 Answers
Scanner image
processing board
(SCIPB)
• Memory control board /1
(MCB1)
• Overall control board
(OACB)
• Printer control board
(PRCB)
any one of the above boards$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ have tech come reflash the firmware first
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on May 14, 2016
SOURCE:
How do I fix error code c-6740 on Konica Minolta c7000pro
C6704 Description Image input time out
Image data is not input from the scanner to the MFP board (MFPB). Remedy 1 Select [Service Mode] - [State Confirmation] - [Memory/HDD Adj.] - [Memory Bus Check] - [Scanner-Memory], and conduct the memory bus function. 2 Check the connectors between scanner section and MFPB for proper connection and correct as necessary. 3 Replace MFPB. 4 Replace CCDB.
Dec 09, 2014 | Konica Minolta bizhub Office Equipment &...
My radio on my 2001 accent wont play cds it says error code 6, does anyone know the security code?
Hi there:
From Hyundai Owners Manual: Er6 - DISC ERROR - CHECK IF THE DISC IS INSERTED CORRECTLY IN THE CD PLAYER.
MAKE SURE THE DISC IS NOT SCRATCHED OR DAMAGED.
Error 6 means your laser isn't reading disc... needs replaced pick up laser. I would try first to insert a clean up CD and test your CD Player with an original CD, if the problem persist, you have to go to fix it to a specialist.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | 2001 Hyundai Accent
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Motorola Razr Bluetooth Error- Failed: Connection Interrupted
Some phone service providers block the transfer of files. It depends on who your service is through. I know Verizon and Sprint block them when I try to send from my phone to others with those providers.
Jun 06, 2009 | Motorola Mobility RAZR V3
I don't know what my problem is I just know I have one.
Uninstall Norton 360.. this will slows down the system..
please check the smtp and pop3
is it correctly configured.
Mar 30, 2009 | Microsoft Outlook 2003 for PC
Aiwa receiver AV-DV75 powers up then down instantly
mi se sfiza aiwa sistmi buferi ali nemam moznis da kumim.....
Jan 02, 2009 | Aiwa AV-DV75
Error 12 message on my sony multichannel av receiver str dg 510
error 12 is what you get if you autocalibrate and do not have the microphone attached.
Aug 23, 2008 | Sony STR-DG510 Receiver
Rx comm error 200082 on receiving fax Ricoh aficio 222SF
I have Dell Monolaser MFP1125, can not send and receive fax
Aug 04, 2008 | Office Equipment & Supplies
What is E6 and toc error
I don't have info for E6, but TOC error means it's not able to read the disc due to dirt, scratches, or other damage.
Sep 25, 2007 | Kenwood KDC-MP235 CD Player
Cd won't play
I had the same error code display on my unit. I was told it was a cd lens problem and had it sent back to the manufacturer for fixing.
Jun 06, 2007 | Clarion DRX6375
Konica Minolta Bizhub Press C6000 Copier Logo
1,233 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
