You need to clean out the sump air vent. and change the filter for the air breather. some are fitted with a clean easy filter you take off and wash out.
This tip will help you learn how to convert new or used vegetable oil into high-grade biodiesel fuel that can run in a standard diesel engine. Anybody can make biodiesel. It's easy, you can make it in your kitchen -- and it's better fuel than the petro-diesel the oil companies sell you. Your diesel motor will run better and last longer on your <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">home-made fuel</a>, and it's much cleaner -- better for the environment and better for health.<br /><br /><a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> has some clear advantages over straight vegetable oil, or SVO: <br /><br />
<ul>
<li>It works in any diesel, without any conversion or modifications to the engine or the fuel system -- just put it in and go.
</li>
<li>It also has better cold-weather properties than SVO (but not as good as petro-diesel<a href="http://journeytoforever.org/biodiesel_vehicle.html#winter"></a>).
</li>
<li>Unlike SVO, it's backed by many long-term tests in many countries, including millions of miles on the road.
</li></ul>
Biodiesel
is a clean, safe, ready-to-use, alternative fuel, whereas it's fair to
say that many SVO systems are still experimental and need further
development.<br /><br /><span style="font-weight: bold;">Instructions:<br /><br /></span>
<ol>
<li>Purchase a <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel Processor</a>, such as the <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Fuelmeister II Biodiesel Processor available here.</a></li>
<li>Follow the included instructions and you will be on your way to creating your own Biodiesel fuel!<br /></li></ol><br />Biodiesel is made from vegetable and animal oils and fats, or <b>triglycerides</b>. <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> cannot be made from any other kinds of oil (such as used engine oil).<br />
<br />
Chemically, triglycerides consist of three long-chain fatty acid
molecules joined by a glycerine molecule. The biodiesel process uses a
catalyst (lye) to break off the glycerine molecule and combine each of
the three fatty-acid chains with a molecule of methanol, creating
mono-alkyl esters, or Fatty Acid Methyl Esters (FAME) -- biodiesel. The
glycerine sinks to the bottom and is removed.<br />
<br />
The process is called <a href="http://www.diversesolutions.org/detail/B0014FKHZ8">transesterification</a>.<br /><br />
<b>System Includes: </b>
<br />
<ul>
<li>Processor Tank and Stand</li>
<li>Pump Assembly</li>
<li>Oil Drawtube Kit</li>
<li>Oil Titration Field Test Kit</li>
<li>Operator Safety Kit</li></ul><br />
<b>Specifications:</b><br /><b><br /></b><br />
<ul>
<li><a href="http://www.diversesolutions.org/detail/B0014FKHZ8">Biodiesel</a> Output: 43:5 gallons (max) per batch</li>
<li>Mix Rate: 330 gallons per hour</li>
<li>Operator: 1 1/2 hour per batch (typical)</li>
<li>Tank Material: Chemical grade polyethylene</li>
<li>Tank Stands: Welded steel frame with levelers</li>
<li>Plumbing Materials: Chemical grade steel valves</li>
<li>Processor Capacity: 55 gallons (maximum)</li>
<li>Processor Size: 54" high x 26" diameter</li>
<li>Footprint: Set up in a 30" x 30" space</li>
<li>Shipping Weight Processor: 98 lbs.</li>
<li>Shipping Weight Pump Assembly: 27 lbs.</li></ul><br />
<b>Other Features:</b><br />
<ul>
<li>Handles most used vegetable oils</li>
<li>Makes 2-40 gallon batches in 24 hours </li>
<li>Industrial-grade materials</li>
<li>Easy draining cone-bottom tanks</li>
<li>90 minutes hands-on time after understanding the system</li>
<li>Turbine pump blends and mixes</li>
<li>Full-draining single tank system</li>
<li>Special Modular Direct Catalyst Injection Lid (Patent Pending)</li>
<li>Steel Methanol Pump</li>
<li>Quick disconnect hose fittings throughout</li>
<li>NEMA box with Solid-State control timer</li>
<li>Steel valves No thru-tank ports</li>
<li>Interchangeable Lid System</li>
<li>Large diameter glycerol drain hose</li>
<li>30" x 30" footprint, very compact</li>
<li>Platform allows for modular upgrades</li></ul>
First, empty your fuel tank and pour a 2% fuel mix in it.
Remove the oil hoses coming to the carbs. Put the ends in 2 recipients.
Run the engine for a few minutes. Oil must come in the recipients. I couldn't find an exact quantity in the Service manuals.
The theoretical mix is 50:1 ( 50 liters fuel with 1 liter oil)
So, the best way is to have a full tank 50/1 fuel/oil mixture AND a full oil tank.
Sail a few hours, refuel ( count how many liter you've burned. Refill the oil tank to level.
Check that the fuel/oil ratio is about 50:1.
You can adjust the mixture with the cable on the oil pump.
Do you smell gasoline in the oil? If you do the diaphragm in the engine transfer pump is leaking. You have to determine why the oil level is rising in order to find the cause.
There is no fuel pump it is gravity feed.Make sure gas oil mix is right, check oil tank level, and check filter.if all are ok then you need to adjust the idler and fuel mix screw.
If the oil level is correct then you might be up for an oil pump. Some engines have an automatic cut-out for low oil pressure or high temperature as a safety mechanism to protect the engine from massive damage.
Need more input here iam afraid ,like make and model and where the leak is if the fuel is mixing with oil do not drive it could hydraulic or even worse run away with itself and just run till it blows up ,once it goes turning the key off will not stop the engine it will run on the sump oil mix and watch a con rod come through the block
I'm assuming this is a 4 cycle engine. If yes check the level of the oil in the crankcase - DON'T over fill, drain some out if over filled. If 2 cycle engine your oil mix is to rich. drain gas from tank and mix a fresh match of fuel with the proper amount of oil.
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
