2005 Ford Focus Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio I have a 2005 ford focus been fine till the other day.Came out to my car radio would not work. Went for days and did not worked even changed fuses. Then all of a sudden the radio worked. Then a few days later I came out of work and the radio would not work again half way home it came back on and would not shut off. Could not even turn up or down volume or stations . When I turned off the car the radio still was on.I had to take out fuse so battery would not run down. If you can help I would appreciate it. when i turn my car off the radio keeps playing and wont cut off. how do i fix this?
Anonymous
Level 2:
  • Expert 122 Answers
  • Posted on Jun 04, 2009
Anonymous
Expert
Level 2:
Answers
122
Questions
0
Helped
62203
Points
290
Sounds like the radio failed internaly you would have to replace the radio and when you put new one in make sure its secure and not over heating
1helpful
2005 Ford Focus. Dashboard dead, no brake lights and blinkers.
AutoZone have some funny ideas!
Problems like this are very hard to diagnose. Call out a local auto-electrician. You need someone with a pro grade scan tool and access to wiring schematics and the knowledge to use both.
1helpful
Radio Buttons don't work
if on off works its not fuse , some radio have a slide behind buttons some have rubber buttons .on diodes ,take off panel and clean ,
2001 Ford Ranger radio was working till a bad storm went over and the next day no radio or power to the radio
look at the ant mast and base for signs of burns if lighting hit the ant it will fry the radio
4helpful
2answers
My fuse went out on my 2007 328i BMW radio fuse
radio went dead...one day working fine, nothing next day. Checked the fuses all good. Any solutions???
1helpful
2answers
Radio in 2009 ford focus does not work checked fuses and they are ok
Check to see if you get power and ground at the radio. If you get power and ground then the radio may be faulty. Also if you get the radio out see if there is a fuse on the back of it and check it if there is one
No warning, but had gone to town earlier in the day, car was working fine till i got home. Car wouldn't shut off, and key would not come out of ignition. had to pull a fuse and disconnect batter.
Sounds like you need a locksmith or mechanic to
replace your ignition lock cylinder.Had the same thing happen to my 04' Ford Focus. Fun.
1helpful
Hello. i have a zx5 2003 ford focus. I changed
battery clamps or terminals loose or corroded, bad ground wire from battery to chassis thats where i would start. check connection to alternator as well
1helpful
Radio
Sounds like the head unit is bad on your audio system. You would need to replace the entire unit. I'd recommend an aftermarket stereo instead of another Ford stereo.
2answers
2001 ford taurus- radio won't turn on
yes there is a 10 amp fuse in the box under the hood
Electrical problems
Sound like the car is not recharging the battery as you drive. Take it to a different shop and ask them to test the alternator and entire charging system as well as the battery.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
