Question about HP LaserJet P2055d Printer
Output bin full - HP LaserJet P2055d Printer
    Master:
  • HP Master
  • 566 Answers
2 Suggested Answers
SOURCE:
termistor
  • 85 Answers
SOURCE: Left Output Bin Full error on HP LaserJet 4345.
check output bin sensor
Posted on Feb 24, 2011
One of our other Hp Laserjet 9050dn printer displays 'Output bin full and Jam paper. What could be wrong.
There must be a problem with the output sensor, dirty, bent or clogged. Check all the paper paths and if possible reset the error code. Regards, Mike
Jan 27, 2016 | HP LaserJet 9050dn Printer
How to output bin empty ?
  1. The output bin may be full. Empty the output bin. Printing resumes automatically.
  2. Take a close look at the flaps hanging out the exit of the printer. They should move up and down freely. If one of them is stuck up, broken or dislodged, then a bin full error is displayed.
  3. Open rear exit tray and power on the printer. If the printer comes to a Ready state, close rear tray and try printing.
  4. Clean the paper path below the toner area and exit assembly at the back of the printer. Ensure there is no pieces of paper stuck in the paper path of the printer.
Jan 20, 2015 | HP LaserJet 5200 Printer
Hp 9050 laser jet stacker error
Probably just a bad sensor or dirty sensor causing the issue.
Stacker or stacker/stapler output bins
For the 3,000-sheet stacker or 3,000-sheet stacker/stapler, the output bins are the upper bin (face-up) and the lower bin (face-down).
The upper bin (face-up) is the top bin on the stacker or stacker/stapler. This bin holds up to 100 sheets of paper in face-up order as they exit the printer. A sensor causes the product to stop when the bin is full. Product operation continues when you empty or reduce the amount of paper in the bin.
Lower bin (face-down) is the lower bin on the stacker or stacker/stapler. This bin holds up to 500 sheets of paper and can stack or staple jobs. This bin is the default output bin.
Aug 19, 2014 | HP Stacker For LaserJet 9040/9050/9500...
REMOVE ALL PAPER FROM BIN ,OUT PUT BIN IS FULL Hi
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 06, 2013 | Minolta QMS PagePro 9100 Laser Printer
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
Output bin full problem what should i do to solve this?
As the output bin accumulates
paper, the output bin delivery flap
rises until a flag blocks the
photosensor (PS911). When the
photosensor is blocked, this
message appears.
Rotate the output bin
delivery flap up and down.
The flap must move freely. If
the top cover has been
replaced, make sure that it
has been installed correctly.
Sep 05, 2011 | HP LaserJet P2055d Printer
HP Laserjet 5200 top bin full
Hi, Remove all the papers from out put bin & check if not solved remove both side and top covers absorve right side of the out put bin flag sensor clean it with high pressure air or clean with dry cloth gently. Best of luck...Vinay
Apr 18, 2011 | HP LaserJet 5200 Printer
Display say "BIN IS FULL"
HP says: 1) remove all printed pages from output bin 2) "flick" the output bin lever with your finger
If fault continues, contact HP.
Nov 27, 2009 | HP LaserJet 4000n Printer
HP LaserJet P2055d Printer Logo
194 people viewed this question
Clive
Clive
Thomas F. Schneider
