https://eautorepair.net/Marketing/Default.asp
No engine told so the HUNT ENds. now.
2.2L or 3.1L? engine./ (USA choice day1 new , 2 engines)
the manual is clear.
rad fan rear? dead, it can be hot wire tested.!
the ECT sensor is used. on all modern cars,,
if PCM scans fail to show ECT failing it is no failing
it will read using any real scan tool PID live data ECT at 180F to 200F
the same manual tells you the trip point, to run the fan,most cars are about 220F, 165F is boiling so 220f is NOT TOO HOT.
if the ECT reads correctly to REALITy, it is NOT BAD ever.
we use an IR THERMAL GUN TO PROVE THAT IN SECONDS WORK.
IF ENGINE IS TOO HOT, AND FOR SURE FAN IS DEAD
THE ECT MAY BE IN AN AIR POCKET AND THAT MAKES IT LIE;.
MAKE SURE FIRST ALL AIR IS BURPED OUT OF THE COOLANT LOOP.
THE CAR HAS LOW COOLANT SWITCH, AGAIN SCAN PCM SEE IT FAIL?
THERE ARE 2 FANS AND 3 RELAYS THE PCM CONTROLS
RELAY 28,29,AND 30
AND FUSE 17 AND FUSE 18 FOR FANS
Engine coolant must be drained below the level of the engine coolant temperature (ECT) sensor.
HERE IT IS #1
F = FLY WHEEL MEANS TRANNY END OF ENGINE.
T= THERMOSTAT.
I BET IT IS GOOD AS 99% ARE REPLACED GUESSING
I'D SAY BAD FUSES X2,BAD RELAYS X3 FIRST.
OR AIR POCKET WHERE #1 RESIDES, LEARN PURGE AND BURP ALL AIR OUT OF THE COOLANT LOOP.
THE FANS ONLY RUN WHEN THE PCM WANTS TO OR ECT READ SUPER HIGH, 220f UP.
OK FOUND IT IN THE MANUAL
223°F) the low speed engine cooling fans should engage.
At 110°C (230°F) the high speed engine cooling fans should engage.
SO 223 AND 230F ARE THE TRIP POINTS
SO 200F NORMAL ,NEVER RUNS FANS
