The Brilliance has a lifetime belt but if it gets overheated it can get warped and comes off. Normally you do not need to replace the belt unless there is a problem. You have to remove the cover over the power nozzle assembly by removing the screws on the bottom. Notice how the belt goes around the motor shaft and through the "Hall Assembly" which is the spring loaded lever that detects a jam and shuts the brush roll motor off.
SOURCE: How to replace belt
Most Riccar's, turn vac over, take off the bottom plate, Brush roll and belt are there. Put new belt over motor shaft, then over brush roll, push brush roll back into place and re-install bottom plate.
SOURCE: Where is the model number on the Riccar Brilliance
As you're looking at the back of the vacuum, the model number should be located on the tag beside the right wheel. If there is no model number there, then the model is simply the name of the vacuum, in this case Brilliance.
