Roper 24 in. RUD3000 Built-in Dishwasher Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dishwater detergent dispencer doesn't open when it should during it's timing cycle.
Dishwasher doesn't dispence the detergent.
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Jun 01, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2971301
Points
24702
HI, this is the result of a damaged Actuator assembly. you will need to replace this assembly. it is a spring loaded assembly that dispenses the detergent.
It is damaged. Replace your
Actuator assembly for detergent dispenser
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
My LG dishwasher is about 1 1/2 years old. My problem is that the detergent is no longer being dispenced properly. Much of it remains in the dispencer after use. What can I do about this?
open the dispenser while the machine is in operation and pour some extra water.
this will make the detergent to flow more inside the machine fully
Sep 16, 2008 • Dishwashers
Thanks for your help. I have a Kenmore Model # 66513782K600 the main soap dispencer did not open during wash cycle can you steer me down the right path to complete repairs. Thanks again Ken.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Apr 24, 2011 • Dishwashers
I have a 13 year old Maytag that works great. But recently the flipper door that dispences the dry detergent doesn't open during the wash cycle. I've tried cleaning it thoroughly, but that hasn't made a...
heatman101
2answers
Dishes not washed detergent still in compartment pump will not stop pumping bosch dishwasher
cycle stuck possibly..........unplug it or turn it off at the main electric box circuit breaker......wait 10 minutes and try it again.........
ZANUSSI 695 Integrated Dishwasher
Most dishwashers work best when the food is rinsed off the dishes before they are put in the dishwasher. Also, run the hot water into the sink until it is hot and then turn on the dishwasher. good luck.
The fabric softner drains out as soon as I pour it in
the fabric softner drains or flushs down in the rinse cycles,,,now if you fill past the line or open in dispencer it will sphion down by it self,,in short your overfilling dispencers,,onthejob
Hotpoint Dishwasher
The dispencer soilnord is broke , change the dispencer.
2helpful
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
The detergent cup can become clogged with old dried detergent that prevents it from opening at time. Sometimes just cleaning the cup takes care of the problem. The detergent cup opened by a bi-metal switch or a wax motor located inside your dishwasher door(behind the detergent cup). If cup's cleaning will not solve the problem, you should replace the bi-metal switch or the wax motor (depend which of them is used in your machine). Another option is just to place the detergent tablet on washer's bottom before starting its cycle. Good luck !
Top Roper Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
