Go to this webpage. Input the model number off of the trimmer. Make sure you have Adobe Reader. Download the manual for your trimmer. View the detailed instructions for the procedure you need.
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
take the spool out there shood be a I hole to push the twine throu tie a not that wont come out look for dirtion or arrow to wind it leave enough to sitck thru the side where the twine cuts push the spool up and lock it
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
the plastic head that cuts has melted need a new on where from?
