My Bluetooth began giving problems when I place a call I could hear the person I am calling, but the person cannot hear me. The unit is turning on and pairing fine and as I said, I can hear the person, but the person cannot hear me.
SOURCE: Bluetooth H710 new..mic not working
Go in phone to setting then go to bluetooth and press it then select voice routing incoming hands-free
SOURCE: no voice or sound
Did you check that you didn't activate mute?
If it is on mute. Press both volume buttons at the same time you will hear two descending audio tones.
SOURCE: My phone shows me that my bluetooth is paired and
I had the same problem. I turned my phone off and then back on and that problem was solved.
SOURCE: i conect my bluetooth but when i recive a call i
That's not your bluetooth. Make sure your phone is not on "mute". It sounds silly, but I know this solution from personal experience. :)
SOURCE: motorola bluetooth instructions n136 pair with IPhone
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
