Philips PSP-LFH0720/52 Model 720 Analog Desktop Transcription Kit, Tape Counter LCD, Auto Backspace Play, Volume/Tone/Speed Control, Fast Erase, Automatic Switch Off, Cue/Preview Function, Loudspeaker Switch, Record Protection, Auto Rewind, Simple Search For Logo
A
Anonymous Posted on Jan 22, 2014
Philips 720 transcription tape runs too fast - Philips PSP-LFH0720/52 Model 720 Analog Desktop Transcription Kit, Tape Counter LCD, Auto Backspace Play, Volume/Tone/Speed Control, Fast Erase, Automatic Switch Off, Cue/Preview Function, Loudspeaker Switch, Record Protection, Auto Rewind, Simple Search For
mark liikala
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jan 02, 2015
mark liikala
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
5
Helped
11433
Points
23
The deck is bad needs a new worm gear for the functioning motor.
A lock sign comes on when i put the tape into my machine which did not come up before
The tape lock sensor is bad and needs replaced relatively cheap fix. around $100
Why 720 transcription system foot pedal not working?
Could very well be a bad plug on the mother board. Common problem with these units
1helpful
I have a 720 Transcription System which I can't erase any data off. There is a padlock symbol on the LED display. How do I get rid of it?
There is a tiny switch in the mechanism that detects if the erase prevention tab is broken off the cassette. Try another tape to see if it is the tape, otherwise, that switch is probably broken. The tab is located to the right of the orange colored area on the picture. There is one one each side of the tape.
2answers
How do I delete tapes on a Philips System 500 Hi-Q please
Press Stop and Rewind together. You could also use Stop and Fast Forward together.
3helpful
Philips 720 transcription machine won't erase tapes - no previous problems encountered carrying out this function with the machine.
Hello Press the PLAY and REWIND keys at the same time the LCD display shows the fast rewind symbol together with an S to indicate that the tape is being erased backward. The erase function continues until either the beginning of tape is reached or another function is selected. if this does not work Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
5helpful
2answers
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Aron
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
