SOURCE: JENSEN VM9312 CAR DVD PLAYER HOW
go to am/fm
then open the settings screen
next on your remote type 5,4,3,2,1,0 listening for each beep
a new screen should come up
after that look for brake override
SOURCE: vm9312 jensen dvd bypass
I just hooked the pink wire directly to the same ground spot as the head unit and it works fine
SOURCE: Jensen VM9312 problems with mp3 cd's and avi DVDs
try cleaning the laser with a CD player cleaning kit....keep in mind Jensen is low-end equipment at best.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
SOURCE: how do i by pass parking brake wire for indash dvd
Hi jason
To answer your question;
You do not need to connect that wire but you need to bypass the parking brake function in the menu.
Here`s the parking brake bypass procedure:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Hope this help Cheers
Testimonial: "good to have a sight that help's get the thing's you buy usable after you leave the store"
