Shutter fires every time advance lever is moved/shutter is cocked.
Unless you are a camera technician, this is a problem that has to go in for repair. The mechanical hold is defective or broken. Please weigh the cost of repair vs buying a used camera
You can buy a used/refurbished AE-1 Program in the $80-$140 range. Call several repair places by looking on the internet, some will give a free repair estimate.
SOURCE: Shutter stuck on Canon AE 1
Just now saw your problem.....I can repair this for you. No it's not "overwound" you possible have some small piece of plastic that caused your second curtain to get hung up and thus jam the entire camera. I have probably repaired 500 AE-1's with the same problem. Art www.flcamerarepair.com
SOURCE: Canon AT-1 (Similar AE-1) Shutter Fires Upon Advancing Film Lever
No need to look at the schematics. It only will give you a little headache. Replace Shutter release magnet (MG#3). While winding stage the Mg#3 suppose to catch the lever and any dirt or particle may prevent it. Clean it and it shoud take care of the problem. Good Luck -James. For further assistance email, go to www.camerarepairjapan.com
SOURCE: Shutter Speed
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
SOURCE: I have an Canon AE-1 and the film advance lever
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
