Sportline 345 Electronic Pedometer Logo
Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset electronic pedometer sdc sportline
Shannon Greer
Level 2:
Sniper:
  • Expert 75 Answers
  • Posted on Jun 02, 2009
Shannon Greer
Expert
Level 2:
Sniper:
Answers
75
Questions
0
Helped
51282
Points
236
Press the reset button and hold for a couple seconds.
http://www.sportline.com/manuals/345.pdf
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3508
Points
Resetting instructions for Sportline SDC:
http://www.livestrong.com/article/201524-instructions-for-a-sportline-electronic-pedometer-sdc/
1helpful
2helpful
I have a new sportline belt clip pedometer. It has 3 buttons: mode,set and r/s. How can the length of stride be entered into it so an accurate mileage reading is possible?
I have an older Sportline pedometer with the same three button arrangement.
My pedometer is set as follows:
First press Mode to get the unit in the Distance mode. Note if the unit is in Kilometers or Miles. (Press and hold Reset for 5 seconds to switch the setting. This will reset the entire pedometer.) Press and hold Set for 2 seconds. The current (or default) step length will appear and flash. Press Set repeatedly until your step length is displayed. It changes by 1" or 1 cm at a time. Then release the Set button. (The pedometer will return to the normal operating mode if you do not press a button for 5 seconds.) When you reach the maximum step length, the unit will advance to the lowest step lenght when you press Set again. Since my step length is actually not a whole number, I rounded down.
A different Sportline step and distance pedometer (the 340) is set slightly differently. To switch from Miles to Kilometers, press and hold Mode when in the Step mode. Then switch to the distance mode and press and hold Set until the step length flashes. Press Reset to advance the current step length by 1" or 2 cm. Then release the button when you have the correct step length displayed. The pedometer will return to the normal mode after 5 seconds with no button presses.
Many Sportline pedometer manuals are available from the company's web site on the product site: http://www.sportline.com . You can look up the model number.
If you add your Sportline pedometer model, I'll be glad to give the specific setting procedure for you.
I hope this helps.
(on her third Sportline pedometer, two had the plastic spring clip fail. They all had similar programming details.)
User manual for sportline 342 pedometer
The manual for the Sportline 342 pedometer is available here: http://www.sportline.com/product.php?prod=12 . Click on Manual.
The 345 manual is at http://www.sportline.com/product.php?prod=15
I hope this helps.
1helpful
I have lost the instructions for my sportline pedometer 350
i have lost my instructions to my sportline electronic pedometer SDC
2helpful
I have the Sportline 350 Electronic pedometer, and I cant figure out how to change the readout from Miles to Kilometers - Cant find the manual anywhere online!
I lost my instructions and I just did a search for the same product sportline electronic pedometer and found this link.It has great instructions! Hope this helps.
http://www0.epinions.com/review/Sportline_350_Electronic_Pedometer/content_249623776900
3helpful
4answers
I have a sportline 345 pedometer. I replaced the
I was looking for instructions for a different model when I found the instructions for the 347 here: http://www.sportline.com/manuals/345.pdf
37helpful
Reset distance mode in miles/not km
to change from km to miles or from miles to km... press and hold the reset button for (at least) 5 seconds (while in the distance mode.) This will reset your already walked info.
Top Sportline Sport & Outdoor - Others Experts
ZJ Limited
ZJ Limited
Are you a Sportline Sport and Outdoor - Other Expert? Answer questions, earn points and help others
