Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
