it takes only 3 things. to run. 1: good motor, compression test. (we do that after any head swap) 2: good spark and spark timed right. you need a book to follow there. 3: good fueling, not flooding and not starving. if #1 and 2 are good, then you can use test fuel to see if motor runs on test fuel (cut fuel pump for test) in that order, and there are simple tests for each.
You might want to check the pick up coil inside the distributer..Also make sure you dont have excessive play in the distributer shaft..Are you sure your losing only fire..What about injection control and fuel..?
Check your kill switch first take the small wire off the the ignition coil you could have a short I would not waste money on a wire harness once the small wire is off the coil thats all it can be is the coil if its not firing if its fuel thats another problem
How do you temporarily resolve the problem Pete?
Do you re-charge the battery or ???
Does it still crank the engine over with the electric start while in the 'failed' state after the 30 min run, just not fire the engine?
Are you doing the spark test with the electric start or kick start?
If charging the battery makes it run OK again for the the 30 mins, that is indicator the charging system is bad and you are running in 'total loss' mode of the battery. When it becomes discharged there is insufficient power to run the bike. You may still have enough power to pass a spark test if tested briefly.
If you can measure the voltage across the battery when the bike is running, that would identify whether the charging system is good - you should get at least 13.5V at the battery.
If not, you may have a stator and/or regulator/rectifier failure.
there is a thermal switch it cuts out the heater element when its at temp. also so has a thermal switch that cut out the unit if it gets to hot. there will be two thermal switches or a combined one. it will have 2 to 3 wire on it and is directly connected to the the drum. one of these is the problem the thermal switch is working as its cutting out the unit. to stop a fire.
You probably need to clean out the pc. Get rid of programs that are not needed or used. Do a "Disk Cleanup", Defrag until it takes only about 1-2 min to complete. Get an Anti-spyware/malware as well as an Anti-spyware program and run it once a week.
You might want to also invest in more RAM. 512mb these days isnt much.
