Also an emerson boom box with same problem: cd's spin but no sound
SOURCE: Sony boom box model# CFD-So1 serial# 2813391 The
This error "disc error",
"no disc present" or " can\'t read cd". This all error are
related to lens problem. If the lens is dirty or if the lens is got cracked or
if the lens is getting blocked then it can happen. The lens is very thin glass
material. You can say the lens is the "eye" of the unit. If the eye
is dirty then it will not see the object. The unit needs to be opened carefully
and this lens has to be checked. If any dust is collected clean it. Using the
cd lens cleaner helps, but if the dust is got stuck hard or if its any other
internal part then the lens cleaner will not help. If the lens is got cracked
then the lens assembly has to be replaced.
You can use dry tissue to clean the lens. once the unit is opened.
In most of the cases, this
problem is not related to cd.But still get the cd checked in any other player
too, this will confirm the fault. Also try other various cds in the boombox cd player and confirm. But if the cds not playing in other player too
then its faulty cd.But this is very rare. Most probably the
fault is related to boom box cd player. In the boom box cd player unit there are two main parts.
One is cd spinning motor and other is cd reading lens(its also called
"EYE" of the cd player).But many times the cd spins internally and
does not play. If you can hear the noise of cd spin inside then its lens
problem and not the motor. But if there is no spin noise in the unit then both
lens and motor are to be checked. The motor is not spinning because its
short/blocked or its connections are got loose. It has to be checked. The lens
is not reading the cd, because its got dirty or its got cracked and faulty. The boom box cd player lens is made up of thin glass and its very delicate. Many a times
dust gets collected on the lens, so the lens stops reading the cd and it do not
play. Some times there is no dirt on lens but it gets cracked, if by mistake
any pressure is applied on the unit or up-side down cd is placed in
the tray or internal short circuit has occurred. These are few
possibilities of lens not working. But in most cases its dirty lens causing
this problem. SO open the tray by pressing the eject button, then unplug the
unit from main power outlet, by keeping the cd tray open. Then take
air blower and blow air in the unit. Please remove, if there is any
cd in the tray while blowing air. Just blow air for few minutes. Then take a
dry tissue and clan the cd placing tray externally and then reconnect the power
and see, if that is helping or not. If the problem is same
as before, then disassemble the unit and clean the lens manually by hand using
dry tissue paper and then see if its helping. But take care while cleaning the
lens with dry tissue you doesn't apply too much pressure on lens or any other
parts. Also before removing any screw to disassemble the unit. Take a marker
with you ready. Just mark the position of parts and screws before removing. If
you have a cell phone with web cam in it then take a photo of the internal
parts before moving any parts. Disassembly is not very hard but reassembling is
not easy. So this pictures and marks with help you for reassembly.
----------But if lens is cracked internally then the lens assembly
has to be replaced. If motor wires are loose then you can easily get
it re-soldered by
soldering machine. You can get it replaced from local cd /dvd player repair
center. They have these parts with them. --------------- This should help.
Thanks. Helpmech.
Check the back of the unit for possible shorts in the speaker wires, no change! take the boombox to a service centre for a repair estimate.
