Master
- Posted on Jan 22, 2014
Re: Ran perfect last yr , gas was stale drained carb bowl...
Sounds like the Needle valve in the carburetor is stuck 'down' letting gas continually run from gas tank into carb. When the valve can't go up (Close) gas will run past the carburetor and into the crank case I bet your oil is full of gas. Check oil level see if it is overfull
