Screwloose IThttps://screwlooseit.com.au > Technical
Press and hold the 0 key for 10 seconds then simultaneously press START. You will then be asked to enter a code. Type "6789" and Enter. That will put you into
Copytechnethttps://www.copytechnet.com > ... > Xerox
Dec 29, 2014 - Re: entering service mode. Press and hold the 0 key for 10 seconds then simultaneously press START. You will then be asked to enter a code. Type .
Don't rush things. If you don't know how a laser printer functions, please don't touch anything. Let someone with knowledge clean the machine. Rubbing the wrong roller, can damage the printer bend repair.
Only clean the parts you are allowed to clean. Like removing dust on places outside the printing area.
If strange and unlogical things happen like this, it might be an electronics lockup. Sometimes it will help to do a factory reset of do the diagnostics.
To go to diagnostics mode: Hold down the back and help button as the Xerox logo moves towards the
center. The machine will eventually say 'Rebooting in diagnostics'.
From there you can run more testing. (Be patient the machine takes a while to enter diagnostic mode).
Testing the Ink Out SensorsUse this procedure to test if an Ink Out Sensor?s flag works correctly. 1.Remove ink sticks from the ink loader?s channels. 2.Place the printer in Diagnostics Mode by: Service method a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears. b. Scroll to and execute test Monitor: Sensors Customer method a.While error code displayed, press UP arrow and OK key. b.Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode.(Printer restarts). c.Select test 82: Monitor Sensors.Press OK. d.Scroll to 01: Exit Diagnostics and press OK to return to customer mode. 3.Insert the clean eraser end of a pencil thru the lowermost oval slot.(The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.) Slide the pencil down the white channel guide until the sensor is tripped.A sensor change is displayed on the control panel.When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L.The test will only display a reading when a sensor change occurs.If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
