Posted on Jun 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Combined photocopying I am using a Aficio 350 photocopier. I have a three page (all one sided) original. I want to copy page one as is, and then page 2 and 3 back to back to end up with a two page document (page 1 on one sheet, page two has page two on the front and page two on the back), sorted and stapled. How do I set the machince to do that? Ginny
Anonymous
Level 2:
  • Expert 162 Answers
  • Posted on Sep 02, 2009
Anonymous
Expert
Level 2:
Answers
162
Questions
Helped
130985
Points
285
Press combines Copy 4 pages in two faces OK and reestablishes the zoom lens to the 100%. press star 1º page 2º page 3º page and (4º page in blank.
They will appear two in front page and one in the back. There is no another form
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
1helpful
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
1helpful
My master lock is locked and i don't know the combination to it
If this is an older masterlock with a serial number, you can fill out the form located here http://www.masterlock.com/pdfs/lost_combo_form.pdf
Read the below from masterlocks website: Due to increased security concerns nationwide, Master Lock recognizes the heightened need for additional safety measures. We no longer provide lock combinations in response to phone, fax, or email requests. Please follow the procedure outlined below to obtain the combination to your lock and submit your request to:
Master Lock Warehouse
1600 W. La Quinta Rd
Suite/WHSE # 1
Nogales, AZ 85621Procedure:
  • Print out the Lost Combination Form from a printer friendly page, or download the PDF file.
  • Have your Lost Combination Form notarized by a Notary Public to prove that you are the owner of the lock (you can include up to 6 combinations on one notarized form).
    • Note: Inmates at a correctional facility - in addition to the lost combination form, you must submit your request on official prison letterhead. In lieu of notarization, the form must be signed by a prison official.
  • Photocopy the serial number on the back case of your combination lock. This copy MUST clearly show that the lock is not attached to anything. Be sure to hand write the serial number on the photocopy.
  • Mail the original completed, notarized Lost Combination Form and the photocopy of the back of your lock to the address above.
Note: It will take approximately 4 to 6 weeks to process your request for a combination.
Note: If the form is not fully completed and notarized with a raised seal or rubber stamped seal, or if the serial number is not legible on the photocopy, your request will not be honored. Master Lock does not reimburse for any Notary fees.
Aug 27, 2011 • Garden
How do i make a photocopy in such a way that the original is copied half the size with 2 copies on the same page?
You put your paper in the copier and use the keys on the menu to reduce the size to 50%. Make 2 copies and put them side by side back into the copier and make one copy.
1helpful
How much can I sell my 10 year old RICOH AFICIO 350 photocopier for?
These dont really have much value anymore. We trade these in and trash them. Ricoh doesnt really support these anymore.
If it has low copies and runs and looks good you could probally get 500.00 from someone that needs one ....
1helpful
I don't know how to copy two pages (size A4) at
open the photo copier put the original copy on top of the screen words facing down then cover the machine then press copy then ok after it will copy, after remove the copy from the photocopier then pull the tray and put that copy on that tray the words copied facing up then put the tray back then open the upper side where you put the original copy then change it to another side, cover the photocopier, press copy then ok it will copy on boss sides.
ERROR of My Aficio MP1500 Photocopier
Are you sure about the model number? I believe you may mean MP2500? Regardless, sounds like an NVRam Problem. This unit is what controls the electronic counter, as well as most of system settings. This will require a service technician from a dealer with connections to RICOH.
Dell printer will print fine but when scanning or photocopying, the left side of the page will not copy.
Refer to this free online website for dell
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?treeid=4F006C0C8C044866841FEF0842919C1D&~ck=gp&servicetag=
Please tell me if you need more info
3helpful
3answers
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
[email protected]
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
