Can fuser rollers be purchased separately rather than purchasing the assembly?
SOURCE: Have a Lanier 5518 with a sc546 code, fuser
Hello sir; According the menual said, that's thermister open or power supply board, but before go that far why don't try to do a reset, steps as follow;
Press "clear mode", "107", then pres and hold down "clear/stop" key, then choice "copier SP" then enter "5810" press enter, select 1, then press"R/#" key and "original type" key at same time to reset, try it and let me know the result. after reset just turn power off and back on.
Testimonial: "Thanks for the help:)!"
SOURCE: I have a lanier lp222cn that has a service code of
tHE sC 40 xx CODE TO REFER THE FAN SUCTION MOTORS.
SOURCE: SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
