SOURCE: sim network unlock pin huawei u8100
Hi, you can unlock your phone with the service available on http://www.fastgsm.com/en/huawei/huawei/u8100/unlocker-unlocking/simlock-reset-key
SOURCE: how to find mac address for huawei 8655-1
go to settings/about phone(status and there is wifi mac adress!
SOURCE: my huawei ascend y 200 won't go online
Hi, if you are using sim card to go online change the sim card and get the saving setting for your smart phone from your sim card company,if you have connecting problem with your wireless make sure that you can connect to any wireless network if you can so your wireless modul is working fine if not you have hardware issues,if you can access the network but not go to the internet from any wireless access point so you may have problem with access point preshared key or DHCP not enabled in you access point or you have restricted because mac address or ip address or network infrastructure has problem with your cellphone so contact your network administrator or network experts,
if you cant connect to any access point so you have hardware problem go to a certified repair shop to fix it(may be your antenna is not attached to your wireless IC correctly or have some harder issues)
kind regard
SOURCE: Pls i need the SIM network unlock code for Huawei U 8650-1 from Tigo tanzania, IMEI: 862076012040587
pls i need unlock code for huawei u8650-1 from tigo TANZANIA imei 862076012040678
