turbos normal make a whining noise under load noise may be present more then before if you have changed anything on the intake side sometimes it can be as little as a lest restricted air filter other cause is lose piping but some power loss would be noticeable if this was the cause
hope this helps good luck
you need to replce the cluch and preasure plate. the clutch is gone, its hard to shift because there is nothing left to pushout on the plate and the squeeling is from the same problem, the clutch works like brakes, when the pads are gone and you step on brake you get asqeeling sound from it being metal to metal the same thing is happening with your clutch
If your car has hydraulic tappets and low low oil pressure at engine speeds then it can make tapping noises. Oil pressure is needed to maintaine the tappets clearances, excessive cleaeances will produce noises.
sounds like your fan clutch may be failing, remove the drive belt and manually spin all the pulleys by have listen for noise and feel for looseness in the bearings
Run 12V directly to the motor and see if it will run, if it dosent than the motor is bad, if it does than the resister is bad, the resister makes the blower run and also regulates the speeds for the blower, but chanses are if it was making a high pitch squeel before it quit the motor went out.
Have your egr valvle checked, if not operating properly it can cause engine 'pinging' which sounds like what u are describing. Let me know how it goes. countrycurt0
