Question about Bulova Marine Star 96C30 watch
My watch has stopped working and the battery is fine
    Problem Solver:
  • 12 Answers
The battery may be bad or installed with the wrong side up. Usually the positive (+) side faces up.
If this is not the problem you may have a bad coil in the movement or the watch needs servicing by a qualified watchmaker.
If you have any further questions please let me know.
Many thanks!
Mike Kenley
TimeOut
Worldwide watch and clock services
If it don't tick I can fix
Posted on Nov 30, 2009
SOURCE:
Citizen eco drive stopped working
Bad capacitor (Titanium Ion Battery)... probably a $30 or so repair on a fine watch.
Feb 17, 2014 | Citizen Watches Citizen Atomic Perpetual...
Brand new Invicta Pro Diver Watch 0923. The watch will work fine for a few days and then just stop working. I will reset the time and it will work for another couple days and again stop working again. I...
If you have any problems with a new watch you should go first to the supplier and if they can't help, contact the maker.
Most makers have a service depot who can help you.
You can find your nearest service depot by going to the Invicta web site (http://www.invictawatch.com/) and clicking on "service " in the menu bar at the top and there is a link to instruction manuals.
The battery should be OK unless the watch has been part of a window display for a considerable time. (Most of the batteries I have used lasted 1-3 years).
May 04, 2011 | Watches
How many batteries does the monte carlo have. the analog side of my watch stopped working.. but the digital side works fine. is it a battery problem?
Hi, don't know the solution for this problem, but i just wanted to say i have the same problem here. And it't the exact same watch. Have you been able to solve it yet?
Sep 21, 2010 | Vestal Monte Carlo MMC001 wristwatch
The light in my watch stopped working. How do I get it fixed? It is a Timex Indiglo(ladies) I don't have any other info.
Most watches of this type have 2 batteries - 1 for the light and 1 for timekeeping. If you use the light a lot, you may have flattened the battery but the watch keeps going because it's running on the other battery. Take it to your local jewellers/watchmakers/watch repair shop and get them to test the battery and replace if flat. If the battery isn't flat and the light doesn't work then you have a faulty watch - if it's still under guarantee fine, if not buy yourself another watch if you can't put up with the fault.
Jul 29, 2010 | Timex 27191 Wristwatch
Will the analog (hands) stop working on a Wave Ceptor when the battery is low/dead? Digital feature still works fine....watch about 4 years old
Yes, definitely analogue part will stop, because it takes more power to move gears and hands. Replace battery and you'll be OK. Rate me, plz.
Mar 16, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I havent worn this watch for about a year the battery has 10 year warranty and was working fine.now it has stopped working.
A few watch companies...Bulova being one of them used to give a 10 year warranty but I dont know of any batteries that actually last 10 years! The average life of a 1.5 volt silver oxide battery is 2-3 years (sometimes a smidge longer) depending on the age and condition of the watch. A 3 volt lithium battery will get on average 3-4 years.
Im guessing that your battery is probably dead! :-)
Jan 18, 2010 | Bulova Marine Star 96C30 watch
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Dec 14, 2009 | Michele CSX Diamond watch
Swiss army stopped, im stressing..
If it's a quartz (battery powered) watch test the voltage of the battery. If below 1.5v then replace with new. Ensure battery contacts make good contact with the battery and are free of corrosion/rust/contamination of any sort. Check operating manual for any specifics regarding battery replacement proceedure.
Jul 26, 2009 | Watches
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Arthur
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Bulova Marine Star 96C30 watch Logo
1,355 people viewed this question
Top Bulova Watches Experts
Arturs Kalnins
Arturs Kalnins
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
