Battery plugged in but not charging
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
SOURCE: lenovo ideaPad U260 built in mic doesn't work
Hello, "Ana Gonzalez".
Your problem sounds like you don't have the software setup right.
Since you could post your problem here,
I suggest that you either use the Lenova website to research this,
or check out the website for their support options.
I've seen a number of systems with software settings improperly applied, causing the microphone to malfunction.
Or to cease to function at all.
Without either a screenshot or the exact name and version of the software, its not possible to more precise.
However, IF you can open the software for the audio control, the volume, and the mic, then you should check to make sure that it is setup correctly.
Hopefully helpful,
sl0j0n
