First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Second Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
The Phone charger and Check The Phone charging If Phone IS Not charging SO Secend Option:Your Phone charging IC Fault So Please change charging IC And cha..
Secend Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
First Option:Please change The Phone Bettery and charger and check The check The Phone charging IF Charging Problem will Not Solved So Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved
First Option:Please change The Phone Bettery and charger and check The check The Phone charging IF Charging Problem will Not Solved So Secend Option:Your Phone charging IC Fault SO Please change charging IC And charging Problem will SOlved thanks.
