Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
A
Anonymous Posted on Jan 22, 2014
Toyo 56 noise - Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
3 Related Answers
Anonymous
  • 8 Answers
  • Posted on Jan 28, 2008
SOURCE: EE2 code for toyo LASER 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Anonymous
  • Posted on Jan 17, 2009
SOURCE: clicking noises
It sounds like your fuel pump is trying to draw more fuel than is available ...So you may need to clean the fuel strainer [should be done once every month of use and before storing ...as you don't want any gunk to harden on the strainer when there is no fuel to keep the strainer moist].
Anonymous
  • 126 Answers
  • Posted on Feb 08, 2010
SOURCE: I have a toyo laser 56 stove. It is starting to
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Toyo Laser 56 throwing EE2 Code on two different units?
PERHAPS IT HAS OUTLIVED IT SERVICE AND NEEDS TOTALLY REPLACED .
1helpful
2answers
I have a toyo laser 56 stove. It is starting to make a moaning noise. what shoud i do?
Pilot,
Tom
We have a Toyo Laser , when it kicks on we get
Tubearz,
You need to look at the igniter guide gasket. That is the gray fiber gasket just behind the igniter flange. When you remove the igniter you may see a black rubber gasket that could be cracked or completely gone. You will need to replace it with the new style ( #17185580). While you are looking, look at the draft tube, where it goes into the fuel sump. If it is cracked it will need to be replaced.
Good luck,
Tom
Toyo Laser 56 EE2 message--no flame? valves open and clean filter
You might of got type 2 fuel oil. If it is a smaller tank sometimes the fueler doesn't clear the line before filling and you'll slug down some type2 which will snuff the flame.
Check to see if the filler kinked a line outside while filling.
Just an Idea...
1helpful
TOYO LASER 56
Here is a link to the owner's manual... look it over to see what may have come unhooked. If you can't solve it you may be able to contact the business for this web site...
http://www.rural-energy.com/publications/catalog/document/270
EE2 code for toyo laser 56
Hi sammysamual,
2answers
Clicking noises
check to make sure the wires going to the main fan are not hitting the blades.
Top Rinnai Heating & Cooling Experts
Paul Carew
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
