A blurry image on a high-definition LCD TV is typically the result of a mismatch between the TV's resolution capabilities and the resolution of the signal that is coming from connected devices, such as a DVD player or satellite TV receiver. Typically, blurry pictures result when a peripheral device connects to the TV through nonHD cables and jacks.
If your TV's connected devices do not have HD capability, they will transmit content to the TV in standard, analog signals. These types of signals are only capable of resolutions of up to 640 by 480 pixels. Pixels, for picture elements, are the tiny dots that make up the screen image. Most HD LCD TVs are capable of resolutions of as low as 1,366 by 768 pixels and as high as 1,920 by 1,080 pixels. When this big of a discrepancy occurs, the images display on the TV scaled, stretched and blurry.
Is ur tv a CRT tube type of a analouge tv u are asking?Yes than the tv don't have HDMI inputs hubs for HDMI cables connections.Only some projection tvs,all plasma,LCD and LED tvs have HDMI inputs hubs only and able give ur tv incomming signals HD 1080i for a broadcasting and HD pictures or throught a HD boxes or games devices like Xbox or Playstation 3 devices to get HD output picture for like 1080p.
Yes,all tvs that are a LCD or a Plama tvs that are a flat screen tvs picture panels can recieving Free over the AIR DTV broadcasting incomming tv channels.Buy and used a Digital design tv Atena for a long and strong recieving incomming tv free signal DTV channels.
U have more than one tv?Yes.Tries check on the other tvs see if u have channel 82 freeview channel,freeview channels are take out or add on all the times by the tvs stantions broadcasting listing.If yes channel 82 is on the other tvs.Than u have low or weak antena signal.U have a analoge antena probally correct?Buy and install a digital antena,u will get a stronger longer ranges tvs incomming broadcasting chaanels tvs stations.Rescan for channels again,u will pick up channel 82 if it still on the air.
The tv u have is a LCD or a Plasma tvs and supported 1080i or 1080p display on ur tv channel display on the tv screen.Yes,than ur tv it is support HD incomming tv broadcasting signal.
Yes,if ur tv is a LCD or a Plasma tvs.It have the tuner inside already it will recieve the digital tv free air brocast.Must have a good antena though like a roof antena,or a digital inside antena.To get excellent signal.So it would cut in and out the broscast of the free digital signal.
Hello: In standard defintion the picture is showing in 480p which is the lowest resolution for LCD televisions, The picture will only look as good as the signal its getting, If you have cable then it should look some what better even with std defintion. The Diamonds/triangles are caused from a weak digital signal or weak broadcast station. This is a normal occurance for LCD televisions as the picture is put on the screen in blocks. I would not say your television is bad, just a poor or weak signal, If you are using a digital antenna and not cable, then you might try purchasing a signal amplifier to boost the signal before going into the set.
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
