Leviton Ivory Touch Pad Light Dimmer Switch Decora Led Logo
A
Anonymous Posted on Jan 22, 2014
Hinge touch pad In hutch doesn't work - Leviton Ivory Touch Pad Light Dimmer Switch Decora Led
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
The wheel doesnt work on my touch pad
Check the compaq website for drivers for the touchpad, if that doesn't work then reboot and try again.
Vgn-cs26g touch sensor not working
my vaio VGN-CS26G' touch sensor panel doesn't work after install Windows 7
please help the basic is Windows Vista after i change it in to Windows 7 touch sensor panel doesn't work
1helpful
Kitchenaid superba kgsc308lssc keypad not working
Hello Ron,
On that touch pad not working do any button at all work?? its not a uncommon thing for the touch pad to quit working,in some case its just a matter of making sure the plug on it has a good connection where it plugs into the control board. If certain button work while others don't its a sign that the control board itself is good and the problem lies within the touch pad and it would need to be replaced. It may possible as to clean the connection of the ribbon cable on the touch pad by using a pencil eraser and try cleaning the ends of the ribbon cable,again if that doesn't work the touch pad would need need to be replaced . On that model the touch pad is integrated onto the control console and the part number for it is 9782418CB just so ya know its pricey (over $200 )
Good luck,GENE
1helpful
My touch pad wont work
please try to un-install and re-install the driver for the touch-pad. if that doesn't work then you have a bad touch-pad and it needs to be replaced. or you can use a usb optical mouse instead. refer to local service tech for parts
5helpful
Touchpad doesn't work
unlock touch pad locking key (Fn and Touch pad icon key on key board OR near touch pad key)
Touch pad does not work. Have tried Fn + F9
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
Hope this helps.
Download worked, Windows7 say it is install and working, cursor does not move
Hello and welcome to FixYa,
This could be one of so many issues.
You could have your touch pad lock on and not realize it;
Did you restart the computer after your download was complete? If this doesn't work;
You could try to re-download your touch pad drivers,
then restart the computer again after installation is
complete.
If you have any more information that could help, let me know and i will find other solutions for you to try.
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
I recently deleted some old files and temp files to free up disc space and when i rebooted, the scroll on the right side of the mouse pad is not working the buttons are and the double click function is too...
The files in temp folder can be safely deleted and have nothing to do with touch pad atleast. Something else might have gone wrong. Just check from the Device Manager or Control Pannel that the drivers for touch pad are installed. If so, check for the scroll option (synaptics touch pad utility) and set it accordingly.
If it doesn't work, you may download and reinstall the touch pad drivers again from the manufacturers support site.
Hope it helps! Good Luck!
CreativeTECH
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
