Vtech Mobigo Learning System Logo
A
Anonymous Posted on Jan 22, 2014
MobiGo stuck on menu screen - Vtech Mobigo Learning System
Vtech mobigo 2 the screen keeps flashing it wont even turn off will not respond to nothing
try this: take the cartridge from both compartments. take out the cartridge. press the on button for 30 seconds. place the batteries back into the toy. try turning it on.
1helpful
2answers
SYSTEM PROBLEM FOUND
You need to update the toy. Connect it to your Learning Lodge Navigator. You should be prompted for an update.
Mobigo 2 cartridges won't play
My son's is doing the same thing just emailed vtech as well
My mobigo stay on the screen that says choose a game
Try taking out the batteries and the game and holding down the "on" button for one minute, then put the batteries back in and try again. The tech support will tell you do that anyway. If that does not work, I would contact them for repair or replacement. I had that problem and that is what I was told to do, they ended up replacing my daughter's mobigo at no charge.
My mobigo is not recognizing cartridges . . . it acts like it is re-booting when I push the cartridge game option. The game works in the other mobigo we own. What now?
Called vtech today about mostly unused mobigo not identifying cartridges, they told me the toy is defective. It was a mobigo 1, which had a year warranty. We bought it too early for my son and it sat on a shelf for almost two years. We bought another from a craigslister whose son never used it only to find the same issue upon opening. Vtech suggested we purchase the Mobigo 2, but I am against doing so after finding out those only have a three month warranty. Quality control isssue?????
3helpful
Hi my mobigo has said that i have one a prize how do i collect it
Hi.
You need to connect the Mobigo to a computer with internet connection On. Use an USB cable, the Mobigo will download the reward. Alternatively contact the manufacturer: http://www.vtechuk.com/about-vtech/contact-us/
5helpful
My son's mobigo screen looks cracked on the inside, not the touchscreen itself. It will turn on but will not load the games.
Does the crack look like it has black ink or lines around it as well? If so, this happened to my son's Mobigo and, unfortunately, the system is now toast. I called the store where we bought it and they told me to call V-Tech because it should still be under warranty. However, V-Tech informed me that it is not under warranty for damage and that they cannot repair their toys at all. There is nothing that can be done with it. They did offer of discount for a new V-tech purchase though.
7helpful
My little sister has a MobiGo and when we try to connect it, the thing would say that it aint connected
Hi nito_juanito
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Before you can connect the MobiGoâ„¢ to your computer, you need to install the
software and register on the MobiGoâ„¢ website.
To begin the software download and registration process, please go to
http://www.vtechkids.com/download to download the setup file and registration
guide.
Once the setup process is complete, connect the MobiGoâ„¢ to the computer using
the USB cable provided.
For the instruction booklet you can download it here at this link..
http://www.vtechkids.com/_f/_pw/_manual/MobiGo%20console.pdf
My mobigo. the screen broke I will LIKE TO know if can be fix
my daughters mobigo screen has a thin black line dowm the middle of the screen although the console still works i would really like to get it sorted before the problem gets any worse can u help please ?
Top Vtech Toys Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Vtech Toy Expert? Answer questions, earn points and help others
